Induction Motoro Rotor Copper losses
The question is:
The rotor of a 3 phase 60hz 8-pole induction motor takes 220w @ 3hz. Find the rotor speed and the rotor copper losses.
Here is what I have done so far:
I have found the rotor speed by using the equation slipspeed = fr(120)/P = 3hz(120)/8 = 45 rpm then finding nsync by 120(60)/8 = 900rpm so rotor speed = 900-45 = 855rpm. Slip can also be found to be 5% from this. I am stuck at trying to find the rotor copper losses though. I thought that it was just the 220w but that seems too easy. I would appreciate any help with this problem. Thank you.
RE: Induction Motoro Rotor Copper losses
Never mind I figured it out. It is slip*(input power to rotor) so .05*220w = 11w
Pretty darned close.
If you want to get sharpen you pencil to get a hair closer:
1 - subtract out your estimate of stator losses and other non-rotor losses from input power first (that should leave you with airgap power).
2 - multiply by s/(1-s)   instead of  s
(2B)+(2B)'  ?
Naughty naughty, no homework help here... read the rules.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
