Custom Cross Hatch Patterns
I have the need to create some custom cross hatch patterns to be used in some drawings, and can't figure out how to do it. These patterns will be used in an area hatch on drawings. If anybody has any insight on how to do this the help will be much appreciated.
RE: Custom Cross Hatch Patterns
Check out this thread from comp.cad.solidworks it may help you. Also you might want to run a search at www.google.com in the comp.cad.solidworks newsgroup
Best Regards and I hope that helps you,
Scott Baugh, CSWP
credence69@REMOVEhotmail.com
http://www.3dmca.com
http://home.insightbb.com/~scott.baugh/
*When in doubt always check the help first*
I would like to have a solid fill pattern, does somebody know what the definition of such a fill would be, so I can add it to the <C:\ProgramFiles\SolidWorks\lang\english\sldwks.ptn> file ?
Aart Schmid
