Flow simulation in SW
The object(a chamber with a filter inside) is ready for the flow simulation, you should close the inlet and outlet as SW prompts you by putting "lids", I did so but it keeps giving the error saying: "The selected face dose not contact fluid or it is an external face of the model"
I changed the lids but still doesn't proceed the flow running to the chamber,
Any idea??
Thanks alot
RE: Flow simulation in SW
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
Thanks for your help anyways,
I owe you a box of donuts,
