ASCE 7-05 Gust Effect Factor - Flexible structures
I am trying to calculate the gust effect factor for a structure that falls into the flexible category according to the code. There is bunch of equations to work through the calc but i get to calculating the R (eqn 6-10) and for RB the equation for n = 4.6*n1*E*B/Vz. The E in the equation is not defined as far as i can tell in the wind chapter but E generally would be for earthquake load. Is this a typo or does the code really want you to put in earthquake load?
RE: ASCE 7-05 Gust Effect Factor - Flexible structures
Thanks for the help. That was what i thought but couldn't find our copy of the errata. Now i know they are online, which makes sense.
