belt conveyor design for conveying lime
what is the arrangement to maintain the moisture content of calcined lime while conveying the material through the belt conveyor.
Does it require any drying arrangement, if so how is it done. Kindly clarify me.
RE: belt conveyor design for conveying lime
This may be the wrong forum to discuss the problem. Try http://www.bulk-online.com/
If you are trying to prevent rain or external moisture from affecting your product, you would need conveyor covers. If you need further drying then you may need a fan to pull waste gas through the conveyor cover space.
