Surface contact
Surface contact
I'm using calculix to model a railway track panel that is being lifted between the bogies of an on-track machine. To model the track support structure (i.e. the ballast) I have created a surface on which the track sits. I was hoping that this arrangement would provide the stiffness I require to support the track, but leave the track unconstrained when I apply a load to lift it from the ground. However, what I am finding is that the track is being constrained to the surface at the nodes defined as contact points. Is there anyway to prevent this and allow the contact nodes to come away from the contact surface?
Rob
Rob
RE: Surface contact
Chris
www.value-design-consulting.co.uk
RE: Surface contact
*SURFACE,NAME=Smast
Ebal,S2
*SURFACE,NAME=Sslav,TYPE=NODE
Nslav
*CONTACT PAIR,INTERACTION=SI1
Sslav,Smast
*SURFACE INTERACTION,NAME=SI1
*SURFACE BEHAVIOR
1.5351e-7,.2
RE: Surface contact
Chris
RE: Surface contact
