SIMULTANEOUS INJECTION OF CHLORINE & FERROUS SULPHATE IN THE CONDENSER
I work at Steam Power Plant 2 x 100 MW. We inject Ferrous Sulphate to the COndenser in order to prevent Condenser from Corrosion. We also inject Chlorine (Sodium HypoChlorite) before the travelling screen to prevent Marine organism from growing up in the Condenser. My Question is Could we inject Chlorine simultaneously with Ferrous Sulphate? Thanks for your attention
RE: SIMULTANEOUS INJECTION OF CHLORINE & FERROUS SULPHATE IN THE CONDENSER
You should only need to add ferrous sulfate periodically.
Do your water conditions change a lot (time of day, time of month, time of year)?
Once you have a good surface film it should be fine. But if the water quality changes a lot then you may need to replenish it more often.
Plymouth Tube
