Error when attemting to create assembly sequence in Motion
All,
I have been using Motion to simulate the mechanical functions of my design. With some trial and error I have got it working pretty decent. Now I want to create an assembly sequence using my animation results from my Motion study. When I try to export the sequence I get the following message: "Can not transform some links into the sequence because they are not defined on component. Do you want to continue?" My options are Yes and No. If I click no it cancels the operation. I've clicked yes twice and created the sequence. The first attempt I only got one component of the study to export out. The second attempt resulted in nothing exported. What does this message mean and what do I do to correct it?
Aaron
Aaron
