Question about non-automatic transfer switch
hi,
i want to design non-automatic transfer switch by 2 contactors and push buttons.
my question is do i need mechanical between the 2 contactors? or it is enough to work with NO-NC for both contactors.
please help me
please help me
RE: Question about non-automatic transfer switch
Big multipole switches rated up to at least a couple of hundred amps are available from the likes of Craig & Derricott, Kraus & Naimer, and a few others.
If you use contactors then you need a mechanical interlock. Personally I'd also use electrical interlock backed up by a mechanical interlock: a plain mechanical interlock usually results in a cooked contactor coil if the interlock comes into play.
Keith Cress
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
I need this to work between generator and main , it is not manual with handle and also not ATS.
can i count on wiring the NO for the first contactor with NC for the second contactor and vice versa
so when the first is on the second is off and when the second is on the first is off.
i don't want the main power get into the generator
Bill
"Why not the best?"
Jimmy Carter
I think change over switch is more a Appropriate
also i will use mechanical interlock
