Can all transparency be deactivated at once?
I detest the transparency feature. I sometimes activate it completely by accident for a surface. You know what happens then. You can't click that surface to save your life, and clicking on transparency controls for the solid body just hides the entire body but doesn't restore that face to full opacity.
Is there any way to select an option to completely restore opacity on all bodies AND faces? I know the tree can restore it for bodies, but I can't for the life of my figure out how to remove the transparency on faces.
I'm using Solidworks 2010.
RE: Can all transparency be deactivated at once?
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
Joe Hasik,
CSWP/SMTL/MTLS
SW 10 x64, SP 3.0
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
NVIDIA Quadro FX 4600
