ECU Tuning Parameters for higher performance
I have been researching performance modifications for a 4 cylinder turbo car and had a question about tuning. When you purchase a "canned" tune to flash to your ecu what parameters are changed? My understanding of a vehicle's ecu is that it is a closed loop system that will automatically search for stoich air/fuel ratio. Is there something that I'm missing?
Thanks in advance,
lurks
Thanks in advance,
lurks
RE: ECU Tuning Parameters for higher performance
ditto for the open loop comments
That would be the major source of any increased power, compared to rev limit, spark etc.
Is your engine diesel or gasoline?
Regards, Ian
Thanks in advance,
lurks
Also be weary of tuners and don't assume they know their ass from a hole in the ground. Back in the day supposed "tooners" for the Evo would tune timing maps to have just 8* above a certain point. The 3d plot of the map was a factory curve below a certain RPM then just at flat 8* above it. No interpolation between either.
A good tuner for a mail order flash (or what ever your process is) has hundreds of maps from all the cars he's tuned on a dyno and knows what different mods do to the airflow characteristics and has a good idea of what will be safe. Then they'll send you what they believe is a fairly safe tune which will alter the fuel and timing maps and possibly boost control if available that will work but may only be 80% optimized for your particular situation.
Another thing a good tuner's flash will do is modify more than just the WOT fuel and timing profile. Anyone can figure that stuff out, its the meat in the middle where real tuner shows his skills.
If you happen to have an Evo a few of the things that also can be modified, 2-step launch control, Flat foot shifting, higher load capacities, Switching to speed density, Pressure based boost control (vs load based), Knock lights, knock and timing safety features, switchable maps, MIVEC tuning (for the 06), larger fuel/timing maps (better tuning resolution), Wideband o2 sensor reading (completely remove the narrowband), and plenty more..
Whats the car in question?
lurks
With all due respect: What makes you think that the present 'tune' (I hate that word) is so far wrong & that you could do a better job than the blokes who developed it in the first place through ad hoc adjustment???
There are so many people online that purport to be some sort of guru - when the sad reality is that they havent got a clue. In actual fact I can see a few on this thread already. My first piece of advice would be to not listen to 99% of them.
Sure I could read an article about brain surgery and throw a few words into a thread - but you wouldnt want me anywhere near your cerebellum.
This forum is infinitely better than most and there are some very knowledgeable guys on here - but the fact that most of the people that actually know what they are talking about have not bothered to comment should tell you all you need to know about this subject matter & the way it often progresses....
Since you are a mech. eng. my second piece of advice would be to go out and buy a copy of JB Heywoods 'Internal Combustion Engine Fundamentals' then read, understand, learn.....and forget all about talk of 'knock lights' etc etc
MS
If you had an LSx engine then this would be a good place to go.
http://www.thetuningschool.com/
Not sure if their info is any help for other makes or models.
The first thing to realize is that a factory engine with a factory PCM is well tuned for the vehicle. However, there is much more to tuning than just changing the fuel and timing.
On drive-by-wire throttle cars you can sometimes change the pedal to actual throttle opening response.
On automatic cars you can change the transmission shift points and converter lock-up points.
On a car like yours with a turbo, you might be able to increase the boost and fuel a bit and extract a little extra power.
On all cars you can do things like change the electric fan set-points or other simple operational things. For example, my LS1 doesn't go to high fan speed until I believe 236 degrees and many people turn down that fan temperature setting by 10 to 20 degrees. The car does get to be very hot with the factory setting, and not just the engine but the radiated heat makes the interior hot too.
And then, beyond these personalizations to a factory car, almost any modifications done require the ECM to be adjusted for the changes.
I have tuned a few different GM engines, using both eproms and flash based computers but I have yet to do anything that was ODB2 - 1996 or newer. I have not got into tuning my LS1 yet but I am thinking about trying it next.
Now, after posting all this I will post one more thing. If you have no clue about this then you have a lot of learning to do. I spent many hours reading and looking at the software and the engine tables to figure out what was going on. Some time driving around watching the engine data helps too (but is not real safe). There used to be a DIY-EFI website with lots of good info but I think it's mostly dead now. Not sure but the Megasquirt website might have some good info on how the system works. In the end, the different make ECM's may appear to work differently but they all do basically the same thing (control the fuel and timing of an engine and sometimes the air too).
OEMs need to make vehicles thatll survive 200k+ miles these days. With A/F rations deep in the 9.x:1 range and timing values extremely conservative, there is a lot of power to be had by getting rid of some of that safety factor.
And while yes, we are reducing our safety factor from over the top for variances (manufacturing, fuel, mechanical tolerances,...), we are doing it in a way we've found to be reliable and using sensors to tell us when its too much. No, my motor will not last 200k but I don't expect it to.
Whats your problem with the Knock sensor? It has proven to be a great tool for safety. When the safety factor is reduced, the knock sensor can be used to reduce timing and turbo pressure and increase A/F ratios. Its all part of the game trying to make power and the light is there just to tell you hey you're knocking, do something about it...Just like the check engine light.
I'm no master tuner, but i don't purport to be one either. Though, its not like I just read an article last Saturday on this either. Ive been tuning my cars (DSM and Evo) since 2002 and have learned quite a bit on what works in my particular situation.
Some of us aren't content with our measly 200whp car but cant afford or don't want some big block factory 505hp screamer.
When you "tune", your vehicle no longer conforms to factory specs and may experience unexpected failures. But there's a lot of tuning space left on the table by the OEM to be taken advantage of (with caveats) as explained by DallasJ. You take your own risk.
I think they do an excellent job of meeting the best compromise within all their requirements.
An individual can choose his own compromises to suit his own preferences.
An individual will normally accommodate compromises he made to a greater extent than those someone else made.
An individual may well decide to compromise legal requirements where the factory engineer must comply to legal requirements.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
But if it is unmodified, and a manual (no transmission tweaks like you'd do with an automatic) then you might spend more on gas doing the tuning than it's worth. Get a few new parts, then tune it.
OEM's are constraint jugglers. Many of those constraints are based more on political fashions than anything remotely connected with function. Ask those clever lean-burn gasoline guys from the 80's how they felt about the TWC strait-jacket.
- Steve
We only do it because it gives us a nice warm self satisfied feeling inside and we actually try our best to make it seem more difficult than it is because it makes us feel better.
All that complexity is engineered in, for a laugh - not to please politicians or the awkward whinging b%stards we call customers or slave drivers we call managers. I just hope we can keep a cap on the 'independant experts' telling everyone how easy it really is & should be....
Of course we all engineer our cars with factors of safety to allow them to run for 1,000,000 miles, with AFRs well past the flammability limit and spark timing which is so retarded it actually increases exhaust temps (perversly requiring more enrichment). We arent trying to ensure that profit margins remain healthy are we.
And naturally, the reams of code & hours of calibrating an active knock system (whilst using incylinder pressure measurment equipement) could be easily done away with by just having some Heath Robinson lights wired up to a piezo sensor - so that you know 'hey your knocking, do something about it' (which is, incidentally, exactly the same ethos that I hear CARB & ECD had in mind for the Check Engine Light).
But then again, our calibrations are indeed 'wildly compromised' across the WHOLE speed/load range not only those low speed/load areas encountered on the FTP-75/MVEG-B drive cycles (where fuel economy & emissions are actually measured & optimised).
Of course the large amounts of run time & processing power that modern engine control systems now posses is a marketing ploy because 'intelligence, knowledge & testing' can all improve power & throttle response (which are obviously all lacking in OEM Elitists....)
What I'm trying to say is that all you really need to do is throw one or two new parts at the car (maybe a nice K&N filter, a red stripe down the side or indeed some of that Schlangeöl) and then nobody will get offended with their 'masterpiece' being messed up.
Or maybe my tongue is so firmly stuck in my cheek its starting to hurt.
Nobody is saying that it is impossible to increase some factors of an engines performance by ad hoc adjustment of the calibration parameters of its control system - but it is always at the sacrifice of some other parameter.
That objective compromise, to meet specific requirements within measurable constraints is what an engineer does. Anything else is just tinkering.
My point was only to highlight the fact that there are many many people who talk nothing but BS about things they only have a shallow understanding of.
Matt
- Steve
I'm sure the major automotive OE's do a splendid job of mapping to the nth degree. But I have ridden many a motorcycle with poor factory mapping. It seems to endemic with companies that are new to fuel injection. Once they have released about their 10th model they seem to get most of the bugs out. We sell fuel injection equipment to OE's and I have seen them do things like make a last minute cam change after the mapping was all finalized. Then they wonder why they get bad reviews. Even companies with years of experience seem to produce pretty awful mapping on new models at times.
Don't get me started on Hardly Davidsons.
Yes, OEMs have magical sensors and test process I have no clue about. Underlying code within the ECU is quite amazing and something I cant begin to break down. Hell, most engineering done on OEM components are quite possibly "gasp" beyond my abilities.
But... I do know the basics of tuning and making power and economy around a race track through the modifications of said parameters. A 9.0:1 A/F ratio, which is what both my 95 Talon and 06 Evo run stock is not conducive for racing power or economy. The OP's SRT-4 is in the same boat. Sure, it'll keep the engine nice and cool for umpteen million miles but I couldn't give a rats-arse about that. I want to be fast and have a spare block on the back burner to toss in when my Fatigue limits are reached.
If you improve the "performance" of the engine one iota from the factory now, it's only because you define performance differently than they do. Within the box of emissions, noise, fuel economy, and engine part life, the factory setting will be absolutely maximum performance. Small manufacturers, and certain low volume products are an exception to this.
It's inconceivable that a guy poking around in the dark is going to find an improvement, even if he is an expert (or even THE expert). He can't know all the interactions or parameters he would need to know (physical or electronic) what's going on in there, and he simply doesn't have the time to test all the variations. High volume engines will have several lifetimes of systematic testing performed before they go to production, by the people that are holding the code book and the hardware blueprints.
It's certainly possible to increase (X) from the factory setting, but it will always come at the cost of everything else that the engine was tuned to meet. If you want to increase HP, torque, fuel economy, whatever, you can. But you will be giving up emissions, noise, fuel economy, HP, engine life, or other parameters that you are not optimizing for.
Matt's point was (I think) that it's not a given that you will even increase the thing you are after any more, at least not significantly. You may make a change that will presumably increase HP, only to run into an interaction that counteracts what you are going for. Further, the opportunity available to increase HP is much lower than in the past when factory designs were not as finely tuned.
It's more difficult to improve now, and there is less improvement available. People who really know what they are doing can get performance beyond the factory tune, if they have specific limited goals and are willing to give some things up.
But, don't tell me that manufacturers would never limit the maximum boost pressure for long term durability or limit the rate of boost application to keep the driver out of trouble in a factory turbo or factory supercharged engine.
Evo 8,9, 10 -- +15-20% hp
STI -- +10-15% hp
SRT-4 -- +5-10% hp
These power gains are from flash alone and no other mods. The evo guys can go from a low 13 sec stock car to mid-low 12s with just a flash and running 92 or 93 octane. Its not rocket science or myth, just facts. Their is A LOT left on the table from manufacturers if youre willing to give up some NVH or life span.
Another thing to think about is the Japanese gentlemen's agreement that limited horsepower to 276 (lifted in 2004). Manufacturers of homolgated race cars overbuilt cars for smaller race teams but limited power by the boost pressure and tune. Not just a few cars here, Evo, STi, Supra, RX7, 300zx, 3000gt, Skyline, Silvia, etc. All limited to 276hp but capable of significant power increases just by playing with turbo pressures.
I really don't know what else to say other than you're ignorant to assume you cant make more power than the "Safe" tunes provided by the factory. Its been done for years and will continue to be done. Hell, even the Prius is getting modded to use both motors for acceleration and increasing electric motor current.
This tends to override the "OEM calibration is perfect so don't touch it" argument.
@DallasJ: "if youre willing to give up some NVH or life span" No kidding... If only I had thought to say something like that, maybe I could've avoided being ignorant.
When it comes to durability, the manufacturer is expected to pay for the engine up to X miles. If you want 15% more horsepower, which decreases durability to 0.65 X miles, they rightly expect you to pay for that. Or, you can do it yourself and void the warranty, which is also fine. On a non-N/A product, you are also throwing emissions out the window, which is an option unavailable to the manufacturer.
- Steve
