Deflection in double contained pipe - PFAxPVC
Hello all,
I need to calculate the deflection in a PFA pipe with double containment in PVC. I also need the stress on the PVC containment, assuming zero stresses on the PFA tubing.
I can calculate the deflection of one pipe, based on single span beam, but, since we're dealing with "double" piping, how does one affect the other? Can I just calculate the deflection in both pipes, and use whatever is the largest? Could it be that easy?
According to Nayyar's Piping Handbook, I can use the same beam deflection equations used for metal piping.
Process - Piping
ing - EiT
RE: Deflection in double contained pipe - PFAxPVC
By the way, how does one calculate the deflection in a full pipe? In the formula for deflection, 5.W.L^4/(384.E.I), what's E, what's I?
In this case PFA tubing containing 96% H2SO4.
Process - Piping
ing - EiT
Never mind, it was easier than I thought at first. Anyway I can delete this thread?
Process - Piping
ing - EiT
Red flag your message and ask that the thread be deleted.
Mike Halloran
Pembroke Pines, FL, USA
