Inspection sample size help
So I have a box with 2000 lets call them marbles. I need to determine how many marbles I need to sample to make sure i get at least one from each of 4 500 marble subsets. How would the number change if i only needed a 95% confidence interval for getting one from each subset.
Thoughts?
RE: Inspection sample size help
So its 1501 to 100% ensure you have one of each.  But I keep coming back to only really needing a 95% certainty which is where things get fuzzy
maybe 1419.
Don't use this if you have a grade riding on it.  I tried a couple of approaches and ended up using autofill in Excel.
However something feels funny about a couple of my assumptions.
Lunch is over so back to work.
Thanks for the entertainment.
Tom
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
I'm not going to spend much time on this so my guess is you multiply the probability of not getting a certain lot by the number of samples until that probability falls to less than 5%. There is a 25% chance of getting a certain lot. So 0.75 to the 11th power is 0.042. 11 samples should have a 96% chance of having at least one marble from each lot. To be precise the probabilities change slightly each time you remove a marble.
Yep, its not a graded thing, unfortunately a real world sampling issue.
Compositepro,
The more i've been thinking about it the closer I think you are.  I was going down a similar path just from the other side of things but your solution seems correct.
Anyone else have any thoughts before we go forward?
