Top level sketch won't update parts
I am working with an assembly (SW 09 SP 5.0).  I have the main assembly and 3 sub assemblies.  Each of the sub assemblies can be sized using the same dimension.  I have used some equations to reference part dimensions to a sketch in the top level assembly.
I got the master copy to work correctly, updating how I want.  This assembly will be used to generate about 50 more variances of this product type.  My problem comes up when I rename the assembly.  The equations do not update.
Any idea how to make this work?
RE: Top level sketch won't update parts
Use DriveWorksXpress. It's already in '09 under 'Tools'.
Beyond that, how are you renaming the assembly?
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
I am using solidworks explorer to rename all the pieces and assemblies.
Forgot to mention that originally.
I do recall something about having to do a couple of rebuilds to get equations to update all the way throughout the tree. After you do your renaming, hit Ctrl+Q a few times and see if that helps.
I think you might want to check out DriveWorksXpress, if you haven't. It's a knowledge based add-in that may save you some headaches.
Jeff Mirisola, CSWP
M9 Defense
My Blog
I do not know how a "Pack & Go " is different to Renaming thru SWX explorer. But I seem to have no problems with a "Pack & Go" plus a Ctrl + Q.
Give it a go & see if that helps.
Cheers
I have had problems similar to that.  Sometimes the equations will not update untill you go into the equation editor.  You don't have to do anything, just hit OK.
I THINK it happens when some of the equations use the values from other equations, but I haven't spent the time to track that down for sure.
There is no solution that I know of other than a macro or that listed above.
Hope that helps,
John
I tried the rename in solidworks explorer, and had the same issue.  I changed the assembly name from assembly.sldasm to newassembly.sldasm.  The equation still reads D1@sketch1@assembly.sldasm.
I used forced rebuild on the top level assembly, sub-assembly, and a part just to make sure.
It seems like I must use Driveworks if I want this to work correctly.
That's kind of what I figured you were seeing.
Try this:
Open your main assembly, update the dimension(s) you need to, File->save as. Before saving, click the references button. In the screen that opens, you can change the sub-assemblies' names and location, as well as the main assembly. I'm not 100% sure this will work for you, but it's worth a try.
Jeff Mirisola, CSWP
M9 Defense
My Blog
