anchor bolt developed length
I need to correct some developed length formulas for the manufacture of anchor bolts. I would like to know if those equations have been given in any standards or handbooks. Any help would be appreciated.
RE: anchor bolt developed length
You could easily calculate the development length of a bent anchor bolt in an infinite mass of concrete, but the other situations will be more difficult.
DaveAtkins
For instance for an L bend anchor bolt you calculate the length of the short leg, the long leg and then you calculate the length of centerline in the bend and that gives you the length of bar you start off with prior to bending.
This has nothing to do with the strength of installing them or their behavior in concrete.
DaveAtkins
Anchor Rods usually are around 10 ft for 2.5" Dia
They use drilled piers as foundation.
