SolidEdge Compatibility
Hello all,
Has anyone had any experience of running Solid Edge v18 on a Windows XP x64?
We have a box which we tried to install it on but it whinges about not being able to find a valid licence whereas we've had  no problems in the past on 32-bit XP.
Any experiences?
RE: SolidEdge Compatibility
You might need a new license file for 64 bit version.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
I think we did, or maybe we didn't get our 'super computer' with the 64bit until we were on V19.
Anyway, as beach says there may be a license issue, or maybe 19 was the first version to support 64bit, I can't recall.
According to our IT dept 64 bit XP is a bit of a pain generally, and certainly Solid Edge V19 is a touch unstable on it, although, in fairness, most of the stuff we do on that machine is pushing the limits.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Hi Guys,
Thanks for your help.  With support having long since gone, I suspect getting an appropriate x64 license willbe virtually impossible.
Ah well, never mind.
You can still run 32-bit SE on 64-bit XP but obviously you will not get the same performance improvement.
bc.
Quadro FX4600.
