Avoid switching rest of assembly transparent when editing a part
Dear All,
when editing a part of an assembly in ProE, I make it active, and when I do so, all other parts of the assembly become transparent (dotted and transparent, to be exact).
Is it possible to avoid that, so the appearance of the assembly remains the same?
I did not find anything for that in config.pro options, but maybe I overlooked something.
Peter
Peter
RE: Avoid switching rest of assembly transparent when editing a part
View > Display Settings > Model Display
[Shade] tab
Uncheck or recheck transparency radio button
I use
d8 @MAPKEY_LABEL> Enable Traansparency
d9 @MAPKEY_LABEL> Disable Traansparency
same can be done for shade with/wthout edges
These don't act as toggles like some other on off options but they work fine with all the possible letter+number combinations.
Michael
