Spiral Bevel Backlash
Would like advice on minimum recommended backlash for spiral bevel gears having normal module about mn=10 mm (Dp~2.5). Power around 1000 kW and speed around 1500 rpm. DIN backlash requirement? Klingelnberg backlash requirement? If possible could you please give your reference source as I want to have confidence in selection.
JWC
Mechanical/Structural
Brisbane, Australia
RE: Spiral Bevel Backlash
Outside (Gleason) or central along the tooth face (Klinglnberg).
Ron Volmershausen
Brunkerville Engineering
Newcastle Australia
http://www.aussieweb.com.au/email.aspx?id=1194181
JWC
Brisbane, Australia
Ron Volmershausen
Newcastle Australia
JWC
Brisbane, Australia
Ron Volmershausen
Newcastle Australia
JWC
Brisbane, Australia
JWC
Brisbane, Australia
