Section Views
Section Views
Section Views
I know how to create a section view; however, I was wondering if you could do multiple section views and put them all on one section view.  Say for example.  I have a circle, and I put a section view down the center.  It will show me that section, but what if I want to add in two more separate section views within that view.  Is such a thing possible when drafting.   Here's a picture for an example.
RE: Section Views
See how I have section C in the picture.  Well how can I have section A and B inside of C as well.
RE: Section Views
I did that but then the stuff from the center cut is missing
RE: Section Views
It sort of comes out. but the bottom is a little shorter.
Would the arcs work.
RE: Section Views
I tried it, and it was a bit more accurate.
