Sheet templates act like Master Drawing templates
So I have master drawing templates that work awesomely thanks to everyone's help here a year or so ago. Unfortunately my supervisors want the 'print' or 'drawing' contained within the same part file for detail prints not as a separate drawing file. For the full assemblies they are OK with the separate drawing file.
Here is my problem, I've edited my 'ugs_sheet_templates' file so that my sheets show up but, they don't hold the Master Model attributes like the Drawing files do. Can I make them use the attributes as I did with my drawing templates or am I SOL?
I'm still on NX6 by the way and really appreciate any help/hints you can give
Thank you
Scott
Thank you
Scott
RE: Sheet templates act like Master Drawing templates
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
until I can change that attitude (and not lose my job in the process) I have to do as asked. If it isn't possible, that is fine since we will just burn up hours manually linking the text to the attributes and eventually prove it isn't the best method.
thank you again
John R. Baker, P.E.
Industry Sector
Cypress, CA
