difference on analysis occured in V14 and V8
V14 vs. V8
1.)
I modeled a simple howe truss in SAP V.14 and compared it with SAP V.8.
i only have released the moments(M2&M3) for the diagonal and vertical members of the truss, having my top and bottom cord with no moment releases.
SAP v. 8 analysis results does not show any WARNINGS.
but SAP v.14 has warnings using the standard solver.
the warning in SAP v 14 goes something like this:
 B E G I N   A N A L Y S I S                                2010/08/18  18:25:13
 RUNNING ANALYSIS WITHIN THE GUI PROCESS
 USING THE STANDARD SOLVER (PROVIDES COMPLETE INSTABILITY INFORMATION)
 E L E M E N T   F O R M A T I O N                                      18:25:13
 L I N E A R   E Q U A T I O N   S O L U T I O N                        18:25:13
 FORMING STIFFNESS AT ZERO (UNSTRESSED) INITIAL CONDITIONS
 TOTAL NUMBER OF EQUILIBRIUM EQUATIONS     =          63
 APPROXIMATE "EFFECTIVE" BAND WIDTH        =          15
 NUMBER OF EQUATION STORAGE BLOCKS         =           1
 MAXIMUM BLOCK SIZE (8-BYTE TERMS)         =         862
 SIZE OF STIFFNESS FILE(S) (BYTES)         =       6.996 KB
 NUMBER OF EQUATIONS TO SOLVE              =          63
 * * * W A R N I N G * * *
 NUMERICAL PROBLEMS ENCOUNTERED DURING EQUATION ASSEMBLY:
  TYPE  LABEL DOF     X-COORD     Y-COORD     Z-COORD       PROBLEM       VALUE
 Joint       7 RX   -2.666667     .000000     .000000 Diag = 0 -->     1.00E-10
 Joint       8 RX   -1.333333     .000000     .000000 Diag = 0 -->     1.00E-10
 Joint       6 RX     .000000     .000000     .000000 Diag = 0 -->     1.00E-10
 Joint       9 RX    1.333333     .000000     .000000 Diag = 0 -->     1.00E-10
 Joint      10 RX    2.666667     .000000     .000000 Diag = 0 -->     1.00E-10
 NUMERICAL PROBLEMS ENCOUNTERED DURING EQUATION SOLUTION:
 Joint      15 RZ   -2.666667     .000000    1.000000 Lost accuracy 15.5 digits
 Joint      16 RZ   -1.333333     .000000    2.000000 Lost accuracy 15.8 digits
 Joint      17 RZ    1.333333     .000000    2.000000 Lost accuracy 15.8 digits
 Joint      18 RZ    2.666667     .000000    1.000000 Lost accuracy 15.3 digits
 EXCESSIVE LOSS OF ACCURACY WAS DETECTED DURING THE SOLUTION OF EQUATIONS
 NUMBER OF DIGITS LOST EXCEEDED 11.0
 THE STRUCTURE IS UNSTABLE OR ILL-CONDITIONED !!
 CHECK THE STRUCTURE CAREFULLY FOR:
 - INADEQUATE SUPPORT CONDITIONS, OR
 - ONE OR MORE INTERNAL MECHANISMS, OR
 - ZERO OR NEGATIVE STIFFNESS PROPERTIES, OR
 - EXTREMELY LARGE STIFFNESS PROPERTIES, OR
 - BUCKLING DUE TO P-DELTA OR GEOMETRIC NONLINEARITY, OR
 - A FREQUENCY SHIFT (IF ANY) ONTO A NATURAL FREQUENCY
 NUMBER OF EIGENVALUES BELOW SHIFT         =           0
 L I N E A R   S T A T I C   C A S E S                                  18:25:13
 USING STIFFNESS AT ZERO (UNSTRESSED) INITIAL CONDITIONS
 TOTAL NUMBER OF CASES TO SOLVE            =           1
 NUMBER OF CASES TO SOLVE PER BLOCK        =           1
 LINEAR STATIC CASES TO BE SOLVED:
 CASE: DEAD
 A N A L Y S I S   C O M P L E T E                          2010/08/18  18:25:13"
Does how does this differ?is SAP v.14 CORRECT?
you can model it on your own.
2.)
and i have used also the multi-threaded solver and deleted the supports for this type of truss and runned the program for analysis. but SAP14 shows "NO" warnings. how does this happen?
please help.
thanks a lot in advance!!
cprr0107
