Custom Properties to XML
The company I am working for mostly uses 2D AutoCad and data is extracted from the drawing title blocks and written into an XML file which is then imported ino the SAP system.
They also use Solid Edge and the same data needs to be extracted from draft files.
Does anyone know of a macro that will extract SE Custom properties and write them into an XML file?
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
RE: Custom Properties to XML
Appears we already have one - but no-one knew !
bc.
Quadro FX4600.
