Mixing SS alloys in a dam saltwater environment
Any problem having different SS alloys in contact in a damp saltwater environment?  Specifically, I'd like to put a 316 collar on a 431 propshaft - but I won't do so if the different alloys could lead to galvanic corrosion.
RE: Mixing SS alloys in a dam saltwater environment
The title of the thread is slightly misleading - I meant to say 'Damp' rather than "dam" smile
You will may get serious corrosion of the 431.
I would suggest that you use a non-ferrous alloy.
Maybe a CuNi.
Plymouth Tube
In my opinion the problem is not the galvanic corrosion, that should be negligible between two stainless steel(see FAQ at page 22 of the doc below)
http://www.euro-inox.org/pdf/map/Contact_with_Other_EN.pdf
The problem that i see is the corrosion resistance of the 431 in contact with seawater. it has approx the same resistnace of SS 304.
"Reasonable resistance to salt water in cold southern waters but less resistant than Grade 316 in tropical waters. Overall the corrosion resistance of 431 is approximately the same as or slightly below that of grade 304.
http://www.azom.com/details.asp?ArticleID=1023#_Corrosion_Resistance_1
http://www.corrosionist.com/Galvanic_Corrosion.htm
S
Corrosion & Rust Prevention Control
