Steel is an alloy
Steel is an alloy
Hello all.
After a friendly disagreement at a recent party, I am looking for your opinions on the following:
Is the expression:
"Steel is an alloy" technically correct?
Something about this statement rings false with me, as I was saying there are many metallic alloys which can be called steel.
My exact argument was that steel is not an alloy, but a type of material of which there are many "recipes", or alloys. It's almost as if "steel is hundreds of alloys" is more correct.
Opinions, anyone?
tg
Is the expression:
Opinions, anyone?
tg
RE: Steel is an alloy
All hinges on the meaning and intent of "an." English is wonderfully ambiguous, and "an alloy" can be used to mean a specific alloy formulation, or to distinguish the object from pure elements, or from mixtures.
TTFN
An alloy is a solid with more than one element. Steel=iron+carbon.
However, the term "steel" does not describe a particular or exact formulation of iron and carbon (much less other impurity/trace elements which can be present). 99.95 lbs of pure molten iron which gets 0.05 lbs of carbon added to it is steel. So is 99.20 lbs of iron with 0.80 lbs of carbon (16 times as much). But the 2 materials will have vastly different strength, hardness, ductility, etc. The first is a "low carbon steel", the latter a "high carbon steel".
Other materials can be alloyed with the metal called steel. Such as chromium. Add a little chromium and you have a "low-alloy steel".
Add more chromium, quite a bit of molybdenum, and maybe some nickel and you have a "high alloy steel".
Add a lot of chromium, a lot of molybdenum, more nickel, and some cobalt (so much stuff that the original iron is a small part of the mixture) and you have a super-alloy.
I'm sure this clears it up, LOL. If it has more than iron, carbon and the trace impurities, it is an alloy of steel.
Yes, it is an alloy.
Did you at least wager a drink on this?
The OP stated,
"My exact argument was that steel is not an alloy, but a type of material of which there are many "recipes", or alloys. It's almost as if "steel is hundreds of alloys" is more correct."
It's a grammar question, not a materials question.
TTFN
You still lose your bet because if steel is unmodified generic term applied to many types of alloys, steel is still an alloy.
Pay the bet and get a life.
No actual wagered amount, just my honour. Worst part of it, it was a stock broker I was sparring with...
I guess I could counter with "management fees are a rip-off", and be correct...
tg
TTFN
Well, in this case, define the connotation of the word "alloy". Do you mean "alloy" as opposed to "pure metal"? Then yes, steel is an alloy. Do you mean "alloy" as in "a specific, unique recipe of elements conforming to a set designation" then no, steel is not an alloy.
What do you mean by the word "steel"?
Actually, tell the stockbroker that he is correct and send him a bill for your time.
definition of steel from SAE J411
Steel— Steel is a malleable alloy of iron and carbon that has been made molten in the process of manufacture
and contains approximately 0.05 to 2.0% carbon, as well as some manganese and sometimes other alloying
elements.
what are different steels called?
When a steel with a specific composition is defined in a standard, it is referred to as a grade. Various designations for steel grades are used, e.g., UNS numbers like UNS G10100 or S30400, SAE numbers like 1010, ASTM or SAE Types like Type 304 (UNS S30400), etc.
but he started...
For the record, I can still beat him at squash.
tg
rmw
