Construction Tolerances
What would be a good rule of thumb for construction tolerances for a gravel road for grade and vertical and horizonal alignment?
RE: Construction Tolerances
plus/minus 15 mm for base course, manually laid (as opposed to using a paving machine. Their "subgrade" tolerance which would likely be more relevant is plus 20 mm, minus 25 mm. horizontal alignment: plus/minus 25 mm.
This is probably a good start; you can adjust to how critical you think that you should be for your road's purpose.
