Object Filtering issue: use of FilterTriple
Hello everyone,
I have started writing up a program in KF that requires the user to select some edges of a solid. For this I use the %ui_comp_selection class, and as a filter I set the FilterTriple as {{70,0,3}}. I have then tested this program on a simple extruded square with corner rads, but for some odd reason I can only select the corner edges, not the straight edges... What am I missing?
Camille Sandaldjian
Camille Sandaldjian
