3D wireframe to flatpattern on a plane
Hello,  I have a 3D complex surface automotive and I have created a wireframe on the surfaces. I need to project this wireframe to plane in order to have a flat pattern.  I am not sure what lic I need to turn on and the steps needed to get the 3D down to a Plane. Thanks in advance
RE: 3D wireframe to flatpattern on a plane
In Generative Shape Design (GSD)
Projection
Set projection Type to Along a Direction
Projected - will be your wireframe
Support is the plane you want the info on
Direction use the same plane as support.
