Wind coefficients for cone shaped roof
I am working with a company that designs steel grain bins.  I am helping better work IBC into their design.  Because IBC can be vague when dealing with non building structures, we are having a hard time determining wind loads for a cone shaped roof.  the roof is about a 30 degree slope, if anyone could point me to a good resource that would be appreciated.  thank you.
RE: Wind coefficients for cone shaped roof
Go to ASCE 7. Most load requirements in the 2009 IBC are referenced from ASCE 7.
That is where i have been looking, unfortunately the ASCE7 does not cover cone shaped roofs. That is why i was asking if anyone knew of any other resource. I might have to try and come up with something by combining round structures, and gable roofs.
See Appendix C5 of the attached document which provides coefficients and methodologies for bins and silos.  Note that this is the New Zealand code - so may not be directly portable to ASCE-7 based design - but should provide a rational basis to help you.
