Elastomer bellows seal tolerance
Does everybody know where to find the elastomer bellows seal tolerance standard? I've found the John Crane's type 21, but I suspect that it can be used for the standard. How about ANSI or ISO standard? I heard from a colleague that the usual one is +0mm/-0.5mm, but if the shaft tolerance is +-0.005mm, is it too tight to install the seal? Thanks for your input.
RE: Elastomer bellows seal tolerance
trust this helps
