Ownership & Use of Software
Hi All,
Suppose a person owns a company in his name and is working as a consultant, so it is basically a one man company. After that he buys an engineering software, in his name (NOT under the company's name). Suppose in the future, his work expands, and he hires a temporary engineer. Can the worker/engineer use the software legally to produce work/service for the company?
Its a bit confusing because the software belongs to the owner, and not to the company. Any advice will be appreciated.
SubseaDeep
RE: Ownership & Use of Software
Providing the software is only being used by one person at a time, I doubt the software vendor will be too upset.
But why not contact the software company and ask?
So long as you don't have multiple copies of the software running, I doubt if the company would even care if you decided to let the janitor use the software.
I'm not even sure why you think there's a problem.  It would seem to imply that buying a toy yourself would mean that you couldn't let your children play with it.
TTFN
I would think that technically as the software belongs to you personnally and not your company you would be in violation of the license. But I'm not a lawyer.
I would think it also depends on the type of company you have created too as to what is yours and what is the companies properties.
Check the EULA, specifically the small print.  Some companies will charge differently depending on usage and enforce that with a license agreement.
On the other hand, if you live in one of those countries where tax is complicated, your purchase may now be tax deductible.
- Steve
