MATHCAD: the symbolic result returned is too large to be displayed
Problem with Mathcad: I have a symbolic matrix 9x9, and its determinant should be the argument of another function of only 1 variable like- f(x). Unfortunately when I evaluate symbolically the matrix, Mathcad returns the text: "the symbolic result returned is too large to be displayed but it can be assigned to a function or variable". That's what i want, but how to do it?
How do I assign it to a function?
Just do a normal assign, eg f(x):= |M| (or |M(x)|, doesn't work!
Please help!!! I'm getting crazy!! It's growing like a quiet private matter.
Thank you very much
Thank you very much
RE: MATHCAD: the symbolic result returned is too large to be displayed
TTFN
Thank you (I apologize for my awful English)
Something like:
x:5 (guess value)
Given (start solve block)
|M(x)|=0
x:find(x) (end solve block and assign result back to x)
TTFN
x:=20
Given
|M(x)|=0 (boolean equal ctrl+)
Find(x)=
Unfortunately when I write Find(x) it bencomes red and Mathcad says: "This variable is undefined"!! (I think it refers to x).
But it is obviously undefined!! It's symbolic, it's a variable, it can't be numerically defined!Is it wrong?
TTFN
(This is the first time I attach a file, I hope that's all ok)
Thank you
TTFN
In the following file there is an easier similar problem resolved (the matrix is 3x3) and the function is graphed too: both problems are solvable, I'm sure.
TTFN
Thank you IRstuff, thank you!
