T-cutter and cutting negative walls
Hello Guys,
Can someone help me with this element? I want to cut negative walls with T-Cutter tool diameter 100, but I'm not so experienced in NX and I cannot find a suitible strategy to cut it.
RE: T-cutter and cutting negative walls
Normally, I would suggest cavity milling with tolerant off, but this looks like a faceted body.
Mark Rief
Product Manager
Siemens PLM
3 axis? 4 axis? 5 axis
J
It's not a faceted body. It's a solid body imported from solidworks file.
I tried to use cavity mill with tolerant off, but it's not what I'm looking for. It generate toolpath up to down for the profile (when I choose profie cut pattern). What I want to do is a rough cutting, profiling of the external edges with end mill cutter and make undercutting with T-cutter and finally, cut negative walls with a T-cutter.
I do not have an option for 4 or 5 axes machines. I need to use 3-axes machine and cut it anyway.
