Vacuum test acc. PD5500
Acc. §5.8.5.5 PD5500 a vacuum test has to be performed (where reasonably practicable).
Is this true?, since non of the other codes have this requirement.
RE: Vacuum test acc. PD5500
which begins with;
Where a test under vacuum or applied external pressure is not reasonably practicable, single wall vessels
subject to vacuum shall be given an internal pressure test at......etc, etc
My point is that for the vessel in question it is reasonably practicable to perform a vacuum test.
I just think that for this vessel(Max./min.design pressure= 7 barg/F.V.)a pressure test based on internal pressure should be enough. In our case we should perform both a normal hydrotest based on internal pressure and a vacuum test.
Because other codes don't consider vacuum tests, I get the impression I missed something in the PD5500. If not , than PD5500 is the only code for which you have to perform 2 pressure tests.
