Motor Current Draw
Motor Current Draw
Motor Current Draw
Is there a way (sure there is) to calculate the new current draw from an existing motor, if i increase the pulley size on a fan?
RE: Motor Current Draw
If you increase pulley diameter by factor f, the fan speed will go up by factor f.  Demanded torque will go up by roughly factor of f^2. Demanded power will go up by factor of roughly f^3.  Motor current should go up by roughly f^3 assuming you are relatively high in the motor current range (let's say above 50% FLA to begin with) so that you can neglect effect of magnetizing current.
There is a big assumption that the system remains fixed (no flow control valves that will adjust themselves toward closed in response to the change), that the system flow characteristic is roughly DP~ flow squared.  Also it assumes efficiency is constant. Finally I think this only holds when the dp is small relative to the total absolute pressure so the density is roughly constant.
(2B)+(2B)'  ?
Very well explained, electricpete -- as always.
Iken:  If you're talking about a not-too-big fan, what I've done in the past to avoid overloading the motor is to purchase an adjustable-sheave type pulley, then increase the fan speeds by little bits while monitoring motor amps.
Of course, stop the fan and lock out the disconnect when adjusting...
Good on ya,
Goober Dave
Thanks electricpete, i have just spent a bit of time sufing the net and found more equations for this also.
