Acad 2007) Up Arrow (repeat last typed input dim's) now failing
Formerly, Acad R7 through 2000, dimemsional input to a command line was repeated when you hit the up arrow on the keyboard.
That is, a numeric input of @3,4,5.625 for the first point could be duplicated (edited), and used again and again.
Now, with Acad 2007, the derived number itself (not the @ relative position actually typed) is duplicated.   Which is usually useless in determining the second, third, fourth, fifth point, etc.
Where was this changed in the new setup/config menus/dialog boxes/acad.ini/mnl's?
RE: Acad 2007) Up Arrow (repeat last typed input dim's) now failing
Look in Help for the system variable Inputhistorymode
____________________
Civil 3D 2008, Terramodel
