Cut and Fill
Cut and Fill
Cut and Fill
Is anyone aware of, or have a copy of, a spreadsheet that calculates cut excavation volumes for a small trench with sloped sides, a flat bottom and an existing grade that may be sloped.  The above x-section information may vary at each end of the trench.
RE: Cut and Fill
It's pretty flat ground... and I was thinking of imputting the grade elevations at the four corners of the segment considered. I tried a net search and ended up spending an hour looking through trash.
Dik
RE: Cut and Fill
dik - I have coded excel to compute ex&fill approximate quantities.  The way I did this was to use an avereage depth (+ or -) between XSECs.  Then I coded my typical section area using the average depth.  This leads to an avereage end volume calculation.  It is not difficult just code it yourself.
RE: Cut and Fill
Thanks, I'll take a look at it this evening... I was able to finally get common formulae for the calculations.
Dik
RE: Cut and Fill
MEM1:
I haven't checked the data for a 'cranked' baseline, but for a straight one, it's bang on...
I wish I could give two stars.  A little 'clunky' but an excellent spreadsheet.
Thanks, Dik
RE: Cut and Fill
Like I said, not very user friendly.  I didn't develop it.  It came from an engineer with the Kansas NRCS.  The guy is a genious with spreadsheets.  An easier user interface would be nice.  For furture reference, NRCS is a great place to find spreadsheets and engineering applications.  Just google NRCS Spreadsheets and you will find a ton.
RE: Cut and Fill
Dik I Star'd him for ya.  That spreadsheet is nice and I found it pretty straight forward.  I may compare it to the INROADS data for a simple section when I find the time.  I personally am a hydro guy so I don't usually need more than a trap section (Channels) and that is easily coded in excel using average depths and a typical section.
RE: Cut and Fill
I did three sections with pline in AutoCAD and got the areas.  Calculated the volume based on distances and found it calculates using average section area and not frustum.  That is, L*(A1+A2)/2 and not L/3(A1+A2+sqrt(A1*A2))  For areas that are not dramatically different, average area is OK. Other than that, calculated values were same as ones I calculated.
Dik
