Cranes for Inland Use - Need Info!!!
I am looking for manufacturers of davit-type cranes intended for light cargo handling or general service on inland waterways.  Any help is greatly appreciated!
Thanks in advance,
Mike
RE: Cranes for Inland Use - Need Info!!!
The most versatile type of crane would be a hydraulic crane,- a company called HAIB make a wide range of hydraulic cranes for both marine and land use, you often see them mounted on the back of trucks or used on barges, small boats, or as small stores  cranes on larger ships.
