HEC-RAS to AutoCAD
HEC-RAS to AutoCAD
I have been googleing for days and unable to find an addon that will enable me to import HEC-RAS data to AuotCAD and vis versa.
Does anyone have an addon they would be willing to share ? as it would help me greatly.
Rob.
Rob.
RE: HEC-RAS to AutoCAD
http://www
I believe that there is a way to create .shp files with HEC-GeoRas that you can import to LDD with the "mapinsert" or "mapimport" command.
Hope this helps.
Works pretty well though.
As Ryb01 said, you can import shape files as layers/object with the Map Menu (AutoCAD MAP).
