Properties Problem
Properties Problem
Properties Problem
Hi everyone
            I would like to ask you please if you can help me to solve a Patran Problem, i have been working with a 3D wing and using 2D shell elements using composite material and when I star the Analysis calculation a window apperatome saying "Some elements in the model have no properties defined "
I checked all model looking element without properties and I cant find it even I put element and nodes in each group corrrectly
Can anybody give an advice to  solve this problem? it is possible to find wich element dosen´t have properties with Patran?
See you in advance
Thank you
Tomi
RE: Properties Problem
Use the utilities group create command based on properties. Any elements without a physical property will be identified and put into a new group.
Thank you so much gwolf2 I really apprecite your valuable help
But how can I do this? how can I know which elements dosen´t have properties?
Thank you see you in advance I hope tohave your answer
Tomi
Use the utilities>group>create command
Hi gwolf Thank you so much again I wil try to do what you advice me before
I hope to find an asnwer and to above problem
Well gwolf thank you again for help me and please we can be
in touch
all the best
Tomi
Hello-
I'm having a similar problem that may have the same solution.
I've created a BAR2 element from two nodes and assigned it a material/property.
I need to rotate and copy this element around several times to make a full 360degree revolution (to make a full ring).
When I use the transform/element/rotate function in Patran, the new BAR2-elements are created successfully but for some reason the properties are not transferred to the new copies.
By using group-elements-with-no-properties from the utilities menu, I am able to create a group that contains these undefined elements.
My question is how do you now assign this group a property-set/material ID?
FYI: I'm currently using the Patran2008r2 interface.
Thanks.
KCHAILI
With that group posted, you can only do Properties>Modify and add those bar elements to the application region.
