Mate with floating offset
New to Inventor..
Is there a way to create a mate constraint with a "floating" offset? I want to make one face parallel with another but I want to be able to drag them afterward.
RE: Mate with floating offset
You should be able to get about any motion you need in an assembly.
I hate to compare but in Solid Edge this is called a "Planar Align" with the floating offset switch set.
Jef
If you can't figure it out attach your assembly here.
I do apologize for any confusion and do appreciate the help.
Angle constraint is what I want. Angle constraint with directed vectors at 180 deg. Thanks a bunch mcgyvr!
Jef
