Parameter in Geometric Tolerance
Anybody know how to insert a parameter into the value field of a geometric tolerance? I have a family table part that I want to vary a geometric tolerance value. I made a parameter and added it to the family table (don't see a way to add a GTOL directly to a family table) but I can't figure out how to get the parameter into the GTOL. Maybe I'll just write a note & embed the parameter.
RE: Parameter in Geometric Tolerance
However, it still didn't work acceptably as the instance value has more significant places than the generic and WF2 rounds the instance value off in the drawing so it looks the same as the generic. ?!?!?!?
I ended up making a note with an embedded parameter.
