ASME Sect. I - Corrosion Allowance?
Does ASME Section 1 comment/require/consider corrosion allowance for calculating wall thicknesses?
RE: ASME Sect. I - Corrosion Allowance?
Refer to the equations per PG-27.2.2 and PG-27.2.4 Note 3. "The values of C below do not include any allowance for corrosion and/or erosion, and additional thickness should be provided where they are expected."
Basically, it is left up to the designer and/or owner to consider.
