how to print to file using vb.net
have a macro written in vba that i am trying to convert to vb.net. The macro prints a drawing to a *.prn file. We then use acrobat distiller to create the pdf, add watermarks, and compile with other documents. I cannot seem to get the vb.net macro to output the *.prn file. I am using the Printout2 Method. Below is the code. Any help would be appreciated as I am new to vb.net.
The first block of Code is the vba macro, the second is the vb.net.
Leyland
VBA CODE
VB.net Code
Leyland
VBA CODE
CODE
Option Explicit
Dim swApp As SldWorks.SldWorks
Dim swModel As SldWorks.ModelDoc2
Dim swDocExt As SldWorks.ModelDocExtension
Dim swDraw As SldWorks.DrawingDoc
Dim SWPrinter As String
Dim PathName As String
Dim PrintFileName As String
Dim nPrintSheets(1) As Long
Dim vPrintSheets As Variant
Dim DefPrinter As String
Dim i As Long
Dim ps As PageSetup
Dim ConvertPdf As Integer
Const OutPutLocation As String = "C:\print files\in\"
Sub main()
Set swApp = Application.SldWorks
Set swModel = swApp.ActiveDoc
'Set swDocExt = swModel.Extension
'Set swDraw = swModel
SWPrinter = "\\HOLTEC-LVAN764\AdobePDF"
ConvertPdf = MsgBox("Would you like to covert the pdf after writing?", vbYesNo)
' Strip off SolidWorks file extension (.sldxxx)
Dim filename As String
'get file name
filename = GetFileName(swModel.GetPathName)
Debug.Print filename
'build filename and location to save files
Dim Answer As String
Dim Rev As String
'get file revisioin
Rev = InputBox("What is the revision of this file")
Answer = MsgBox("Is this a draft Drawing", vbQuestion + vbYesNo, "WELL?")
If Answer = vbYes Then
PathName = OutPutLocation & filename & "R" & Rev & "_DRAFT_" & Date & ".prn"
Debug.Print PathName
Else
PathName = OutPutLocation & filename & "R" & Rev & ".prn"
End If
'Don't know why this needs to stay but macro will not work without it
nPrintSheets(0) = 0
vPrintSheets = nPrintSheets
PrintFileName = PathName
'create poscriptfile with correct naming convention
swModel.Extension.PrintOut2 (vPrintSheets), 1, True, SWPrinter, PrintFileName
Debug.Print "im done"
If ConvertPdf = vbNo Then GoTo EndMe
Call OpenDistiller(Answer)
EndMe:
MsgBox ("i'm done")
End Sub
Public Function GetFileName(FlName As String) As String
'Get the filename without the path or extension.
'Input Values:
' flname - path and filename of file.
'Return Value:
' GetFileName - name of file without the extension.
Dim posn As Integer, i As Integer
Dim fName As String
posn = 0
'find the position of the last "\" character in filename
For i = 1 To Len(FlName)
If (Mid(FlName, i, 1) = "\") Then
posn = i
Debug.Print (i)
Debug.Print (posn)
End If
Next i
'get filename without path
fName = Right(FlName, Len(FlName) - posn)
Debug.Print (FlName)
Debug.Print (fName)
'strip off solidworks extension Solidworks file extensions are 7 characters
'long including the period
fName = Left(fName, Len(fName) - 7)
Debug.Print fName
GetFileName = fName
End Function
Dim i As Long
Dim ps As PageSetup
Sub main()
'get file name
Dim Rev As String
'get file revisioin
Else
End If
nPrintSheets(0) = 0
EndMe:
MsgBox ("i'm done")
End Sub
'Input Values:
'Return Value:
Dim fName As String
posn = 0
posn = i
Debug.Print (i)
Debug.Print (posn)
End If
Next i
Debug.Print (fName)
Debug.Print fName
GetFileName = fName
End Function
VB.net Code
CODE
Option Explicit On
Imports SolidWorks.Interop.sldworks
Imports SolidWorks.Interop.swconst
Imports System
Imports System.IO
Partial Class SolidWorksMacro
Public Sub main()
Dim swDoc As ModelDoc2 = Nothing
swDoc = swApp.ActiveDoc
swFileName = swDoc.GetPathName
Debug.Print(swFileName)
'cheCk if file has be saved at least once
If swFileName = "" Then
RetVal = MsgBox("File Must Be Saved. Please Save File And Try Again.", MsgBoxStyle.Exclamation)
Exit Sub
End If
'Check to see if file is a drawing
Dim FileType As String
FileType = CheckFileType(swFileName)
If FileType <> "DWG" Then
MsgBox("The Current Document Open In Solidworks Is Not A Drawing. Please Open A Drawing File.", MsgBoxStyle.Exclamation)
Exit Sub
End If
'BUILD FILE NAME
Dim FileName As String = GetFileName(swFileName)
Dim Rev As String = InputBox("What is the revision of this file")
Dim Answer As String = MsgBox("Is this a draft Drawing", vbQuestion + vbYesNo, "WELL?")
Dim pathname As String
Dim Mydate As System.DateTime = System.DateTime.Today
'Dim mydate As System.DateTime = System.DateTime.Now
Debug.Print(mydate)
pathname = OutPutLocation & FileName & "R" & Rev & "_DRAFT_" & mydate & ".prn"
Debug.Print(pathname)
Else
pathname = OutPutLocation & FileName & "R" & Rev & ".prn"
End If
nPrintSheets(0) = 0
Dim vPrintSheets As Object
PrintFileName = pathname
swDoc.Extension.PrintOut2((vPrintSheets), 1, True, swPrinter, PrintFileName)
'Call CreateDirectory(PlotFileDirectory)
'Call CheckIfFileExist("3996.PDF")
End Sub
Public Function CreateDirectory(ByRef MyDirectory As String) As Boolean
'Check for Directory
CreateDirectory = False
Dim MyDir As New DirectoryInfo(MyDirectory)
If Not MyDir.Exists Then
MkDir(MyDirectory)
Debug.Print("Created directory:" & MyDirectory)
CreateDirectory = True
Else
Debug.Print("Directory Found. directory was last accessed on: " & MyDir.LastAccessTime)
End If
End Function
Public Function CheckIfFileExist(ByRef Myfile As String) As Boolean
CheckIfFileExist = False
Myfile = PlotFileDirectory & Myfile
Dim CheckFile As New FileInfo(Myfile)
If Not CheckFile.Exists Then
RETVAL = MsgBox("FILE" & Myfile & " NOT FOUND. WOULD YOU LIKE TO WAIT AND TRY AGAIN?", MsgBoxStyle.YesNo)
If RETVAL = vbYes Then
CheckIfFileExist(Myfile)
Else
Exit Function
End If
Else
Debug.Print("FILE: " & Myfile & " FOUND. FILE WAS CREATED ON: " & CheckFile.CreationTime)
End If
End Function
Public Function CheckFileType(ByRef ModelFilePath As String) As String
Dim ModelPath As String
ModelPath = Right(ModelFilePath, 6)
ModelPath = UCase(ModelPath)
Debug.Print(ModelPath)
Select Case ModelPath
Case "SLDPRT"
CheckFileType = "PART"
Case "SLDASM"
CheckFileType = "ASSY"
Case "SLDDRW"
CheckFileType = "DWG"
End Select
End Function
Public Function GetFileName(ByVal FlName As String) As String
'Input Values:
'Return Value:
Dim fName As String
posn = 0
posn = i
Debug.Print(i)
Debug.Print(posn)
End If
Next i
Debug.Print(FlName)
Debug.Print(fName)
Debug.Print(fName)
GetFileName = fName
End Function
''' <summary>
''' The SldWorks swApp variable is pre-assigned for you.
''' </summary>
Public swApp As SldWorks
Public RetVal As Integer
Const swPrinter As String = "\\HOLTEC-LVAN764\AdobePDF"
Dim swFileName As String
Const PlotFileDirectory As String = "c:\Print Doctor\Plot Files\"
Const OutPutLocation As String = "c:\print files\in\"
End Class
Imports System
Imports System.IO
Public Sub main()
Exit Sub
End If
Exit Sub
End If
'BUILD FILE NAME
Debug.Print(mydate)
Else
End If
nPrintSheets(0) = 0
End Sub
MkDir(MyDirectory)
Else
End If
End Function
Else
Exit Function
End If
Else
End If
End Function
Case "SLDPRT"
Case "SLDASM"
Case "SLDDRW"
End Select
End Function
'Input Values:
'Return Value:
Dim fName As String
posn = 0
posn = i
Debug.Print(i)
Debug.Print(posn)
End If
Next i
Debug.Print(FlName)
Debug.Print(fName)
Debug.Print(fName)
GetFileName = fName
End Function
''' <summary>
''' </summary>
End Class
RE: how to print to file using vb.net
