how to read nodal value instead of integration value
I am trying to read a nodal S22 value of a model using Python as:
odb.steps['Parallel'].frames[1].fieldOutputs['S'].values[0].data[1]
How can i change position from the default Integration value to nodal value ?
RE: how to read nodal value instead of integration value
Not sure how to read at nodal values. If you are trying to interpolate based on nodal position and values, will you be able to read values at integration points and use the element centroid?
