CA6 NM Operating in Hydrogen Gas Environment
I am planning to use CA6NM heat treated to Brinell hardness of 300 – 350 HB for compressor casing and rotating elements to handle hydrogen gas of 85% to 99.9% purity. I would appreciate receiving any information or experience in using CA6NM or similar materials in hydrogen gas environment.
Thank you.
Metwd3 (Materials)
Thank you.
Metwd3 (Materials)
RE: CA6 NM Operating in Hydrogen Gas Environment
FYI, if you ever need help welding this stuff, I can - it is my signature alloy, from my days in the hydro turbine business.
metwd3
In my opinion hardness of 350 BHN is high if you need adequate toughness. Those with hydro turbine castings will support me. Double temper and have your hardness in 240-260 BHN range,then All is well!
The rotating element may require further evaluation regarding choice of material and suitable tensile yield because I would not design using 70% of tensile yield for this type of application. What about fatigue from torsion and bending?
I would determine the service stress (considering dynamic and fatigue loading conditions in service, adequate toughness) based on analysis of the rotating elements and from there decide on material selection using a minimum strength level containing a proper design factor.
