Curve number for gravel parking area
I need to find the curve number for a couple of gravel parking lots.  All I can find in the curve number tables of Hydrocad and TR-55 is gravel with right of way included.  The numbers for that have to be lower than for just plain gravel pavement.
I am guessing close to 98 but I don't want to overdo it either.
RE: Curve number for gravel parking area
It's unfortuntate the the SCS didn't publish a specific value for gravel road surfaces excluding the right-of-way.
However, if you examine the TR-55 values for gravel road with ROW, they appear to be based on 30% gravel with CN=96 and 70% "open space" in poor condition.  So 96 would be a reasonable value to use for the gravel alone.
Peter Smart
HydroCAD Software
www.hydrocad.net
I'd take 98 for peak flow estimation.
If it's for a volume of runoff though, you may want to choose something little lower and this will probably give you an head ache.
It's not an exact science...
I'd go with Peter's answer.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
"Gravel" parking lots don't necessarily stay "gravel" for extended periods of time. A higher CN, as the forum has suggested is reasonable.
I'd think about the kind of traffic that will be on it as well.  A "B" HSG sub-grade might compact to a "C" or "D" (essentially CN 98)if there is heavy construction traffic like a haul road, but might not if the lot is intended for long-term parking of small cars, or empty truck containers (closer to CN 96).
Same issue if the lot is constructed on compacted fill as oppose to natural ground.
