Pipe Material for Clarified Water
What is the material of choice for clarified water? Is galvanized pipe sufficient?
RE: Pipe Material for Clarified Water
Do a test on the water. The pH is usually an adequate indicator, which can be checked with the pipe supplier.
In the mining industry we tend to use Polyethelyne Pipe.
