B16.5, Section VIII, and dual cert. SS
Consider a flange, SA-182 F304 150# class, having a rating at 1000°F of 20PSI. Now what arrives at your shop is certified as SA-182 F304/304L.
If my dual grade philosophy is to consistently use the stress values for the straight grade material when considering pipe and plate, am I justified in using the RATING for the SA-182 F304 flange material in keeping with this philosophy?
Fitter, happier, more productive
RE: B16.5, Section VIII, and dual cert. SS
Mike
Dual certified is just that. Its your choice which material certification you wish to consider - but for Code purposes you have to choose one and stick with it. For example, you can't list a flange on Code paperwork as dual certified and use a "straight" grade rating for pressure and "L" grade for welding procedure.
See also II-D Appendix 7.
jt
