adding amines in a steam system
WE have a 125# steam boiler system and the chemical guy is adding neutralizing amines to the feed tank with a preheater. Is this the proper place or should it be after the boiler after steam is produced?
RE: adding amines in a steam system
By coating the inside of the piping/coils, etc. it protects the piping from corrosion from such as carbonic acid, as an example.
Also, is your BFW system modulating or on-off? That may make a difference as to where you pick to add the amines.
rmw
