ASME VIII div 1 ug-34 (f) Continuation of shell option
I am working on a pressure vessel sub-assembly that requires a flat head welded into a nozzle 17.5" dia.
Due to the wall thickness I will have an extended skirt from ASME VIII div 1 ug-34 (f) Continuation of shell option. The shell thickness shall be maintained along a distance inwardly from the inside face of the head. What is the rational for determining the inside face.
RE: ASME VIII div 1 ug-34 (f) Continuation of shell option
means you are not allow to thin the shell . not outside skirt. genblr
